Bending purfling for pegheads http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=3747 |
Author: | Michael Dale Payne [ Mon Nov 07, 2005 9:53 am ] |
Post subject: | |
I am in the process of redesigning the edges of my Pegheads to small radius corners in lue of mitered corners when bound and purfed. I want the inside radius of the purfling to be .125" r.. My solder iron makes a good bending pipe for this radius but with fiber purfling I having about a 50% success rate of completing the bend with out the fiber splitting, no matter how slow and careful I bend. I am much more sucessfull with wood purfling .01/.02/.01 bwb maple than with the same in fiber. I figured it would be the other way around. Any thoughts? |
Author: | Brock Poling [ Mon Nov 07, 2005 12:16 pm ] |
Post subject: | |
are you using a backer? I have pretty good luck bending really fragile things when I use a flexible metal backer. Have you tried that? |
Author: | Keith M [ Mon Nov 07, 2005 12:49 pm ] |
Post subject: | |
I think I would use individual strips of fiber and glue them on all at once. Much easier to make tight bends. |
Author: | Michael Dale Payne [ Tue Nov 08, 2005 12:51 am ] |
Post subject: | |
yep in the out side. have to have it or they tear every time. Keith is probably right. Bend them and lay them up one at a time |
Author: | John How [ Tue Nov 08, 2005 2:18 am ] |
Post subject: | |
Have you tried wetting the fiber? not much probaly or they'll fall apart. I bend them around 1/4 pearl dots quite a bit. |
Author: | Michael Dale Payne [ Tue Nov 08, 2005 3:58 am ] |
Post subject: | |
no, I did not figure that wetting the fiber would help but I will try tonight |
Author: | Pwoolson [ Tue Nov 08, 2005 5:23 am ] |
Post subject: | |
Michael, I once boiled some fiberboard and the 1/4 x .010 stuff would bend around a pencil when I was done. Might give that a try. |
